0 Members and 1 Guest are viewing this topic. Read 2839 times.
If the DAC is situated next to the stereo (and transport) then I would need a 15 ft USB cable to connect the PC to the DAC. I have read that running a 15 ft. USB cable is probably not such a good idea though. Would a 15 ft. S/PDIF be any better - of course then I need a USB to S/PDIF converter.
I had not thought about wireless. Let me see if I have this right. There is software that goes on my PC that allows me to stream music over my wireless network. The squeezebox receives the music via the wireless network. The sqeezebox is connected to my integrated amp via RCA cables or it can be connected via digital out to another DAC of my choice. Is this how it goes? If so, it sounds like a good solution. I would just buy an inexpensive CD player and a Squeezbox and I would be set. How good is the DAC on the SB?
15 feet is nothing for an S/PDIF cable. Very doable.
Why would you need a cd player if you had all your music on a hard drive?
