0 Members and 1 Guest are viewing this topic. Read 31385 times.
Shape isn't an issue.........it's a function of distance. The shape can and does affect amplitude. Taper affects fundamental tone.
On top of all of this good stuff is the inclusion of the possibilities of:Internal tone arm wire rattling.Screw shell head wires rattling.Tonearm lock vibrating when not in the "locked position".The stylus guard on the cartridge rattling.Cueing lever vibrating.Dial on counterweight vibrating.Counterweight vibrating, sometimes in sync with the dial.Linkages under the tonearm (for auto and semi-automatic TTs).Any small springs, linkages, pinnings or what ever, under the TT.Motors vibrating, humming.Capacitor(s) humming, vibrating (starting capacitor, switch capacitor).Transformer (direct drives, crystal controlled belt drives).What else?Wayner
David,If you have an oscilloscope and test records you'd know better than I, how to check transient response. I'd think square wave response would tell you everything you need to know. You'd be able to see overshoot (underdamped) and rise time. Is this the JVC? I can't recall if it's a dial or goo up top. It might be easier to clean it out and start from there, if it's goo.Check the low frequency resonance amplitude at the same time. It should be interesting. I'm curious about the relationship between optimal cart damping vs low frequency resonance.neo
A square wave on a test record is something I've seen from time to time, but it always makes me ponder. So the groove on the test record has to look like the square wave on the scope, so that means the stylus will hit a brick wall, so to speak. We have a moving mechanical device (the platter) which we have some how put a digital signal on (a square wave). Most un-natural for a stylus or music for that matter.The square wave is a digital signal. It is either on or off. It has instant on and off values and is basically pulsating DC. How much distance does a record groove cover in a millisecond?I need to go have some tea.Wayner
what instrument plays a perfect sine wave?
Pipe Organ!And a great way to test your speakers, amps, and window mountings / fittings.....
OK you guys, is a test record a necessary tool? I've gone 40 years without one
A properly set up table with a nice quiet record will blow you away
QuoteOK you guys, is a test record a necessary tool? I've gone 40 years without oneI have a Shure ERA lV test album that only gets the test bands used to check arm resonance.I have a few favorite well known tracks that i use to dial in VTF and bias on various albums.My son did find some very interesting albums for me that have no lead-in grooves from track to track.(locked tracks) It comes in a kind of a suit case made just for the albums. It appears to be a teaching collection. 16 albums total.........mostly classical works. some of the albums have music on one channel, and vocals on the other channel. The instructions are to move the balance knob right or left to isolate the parts. Seems like a nice way to check azimuth. All of the albums are un played.......heavy vinyl that looks exceptionally clean. He found it for $4.00 Produced by Columbia Special ProductsI used to have (many moons ago) a pink noise album for setting up graphic equalizers along with a ratshack DB meter.........I still have the meter.......don't know what happened to the album.
