0 Members and 1 Guest are viewing this topic. Read 31384 times.
My concern in all of this though, is how much of an audible effect Resonant Frequency matching really has and if we convince ourselves that 10Hz is the magic number, how much we might restrict cartridge choice because of this.I've read many posts where 10Hz is sought as some form of Holy Grail - I think we do need to put this in some form of balance.Personally I don't believe I had any audible issues with either of these carts while playing music (as opposed to test discs).Both performed admirably at their respective price points, and I did'nt feel it necessary to apply any form of resistive loading mods to adjust their tonal characters.CheersDave
the question for me is....how much damping do i need to help the cartirdge with.
So, I hope you don't get blasted into the weeds on this from certain quarters, as these are my experiences, too John
I like putting a small dot of plasticlay directly on the arm tube near the arm clamp area, or about 2 inches this side of the pivot bearings. Some experimenting is in order here, and I agree with bas's comment about sucking the life out of the cartridge/arm with too much damping. Just enough to take the ringing out of the tone arm tube is the trick. I have noticed more ambiance in the recordings using this technique, and now I have the dot on all of my arms.Wayner
Yes.
Good............because it's easier to explain concepts using other known common devices.The strings on your guitar when only touched....at certain frets will create harmonics. The lowest of these in pitch vs the open string is the 12th fret. Then 7th/19th fret then 5th fret. The 12th fret is half way between the two termination points of the string. Nut and Bridge(saddle). Touching the string at the 5th and 7th fret will cancel almost all string sound (resonance).Using the guitar neck as an example of distance.......and considering the stylus location as the saddle, and the bearing as the nut. You can put some damping material at the distances figured by ratio at the 19th, 7th, and 5th.When i modify AR XA/XB arms I use a piece of foam ear plugs at those spots internally (as they try to expand and keep pressure applied) It does wonders. You might experiment with the material you are using at those three points and see if you get improvement. The idea of damping is to stop resonances that interfer with termination. A unipivot in design of the pivot just about cannot lose termination at that point, you can still lose termination at the stylus though. An arm such as a Linn has a total of 10 points at the vertical pivot that can lose termination (bearing chatter) The chatter has to start due to the arm tube resonances......eliminate the odd order harmonics.
Foam ear plugs inside the arm tubes to break up arm tube resonances - quite cheap and trick, Bammer; thanks for that mind stimulant
The arm tube is not like a guitar, it doesn't have multiple strings, stretch from one end to another. It's more like a pole. In my experiences with lighting standards (light poles), they would vibrate themselves to death, because of their length, wind speed and wind load. We invented pole dampers that when set in the proper position, stopped even order harmonics, not some of them, but all of them. Odd order went away, as there was not as many wave lengths to become sympathetic with. The even ones could chum up easily, because 2 goes into 4 goes into 8 etc.This is my approach. Do I think it works? Yes. I can't prove it with measurement, but my ears tell me the sound stage has gotten larger, the subdued details like ambiance, reverb and the like are more present. This tells me that nasty wave canceling elements are being muted, allowing these small details to come thru.Wayner
So any calculations as to the optimum spot for plasticene dots? And how does this change with differing tonearm lengths and shapes? (J, S, Straight.... tube, tapered, etc...)Or is it (like so many things in this hobby) trial and error, suck it and see.... or rather: try it and listen, then again, and again, and again, and again......(starting to sound like a "broken" record.... - I wonder how long sayings like this will survive in our ever more digital world)bye for nowDavid
