Question about Speaker and Room Placement
0 Members and 1 Guest are viewing this topic. Read 1655 times.
Early B.
« on: 29 Mar 2011, 12:06 pm »
I'm not sure where to post this question, so I thought I'd ask those people who were smart enough to buy VMPS speakers --  what makes some speakers more sensitive to room placement than others?
jimdgoulding
Re: Question about Speaker and Room Placement
« Reply #1 on: 29 Mar 2011, 02:31 pm »
Types of drivers.  How they radiate like are they front firing, dipole, etc.  The manufacturer should be able to advise, I should think.  Conventional box speakers will usually benefit from the Cardas method (check the Cardas site) or some variation thereof.
John Casler
« Reply #2 on: 29 Mar 2011, 11:57 pm »
That is a small question with a need for a REALLY BIG answer, and I am a slow typist.
And I think Jim above offered an excellent "readers digest" version.
Placement will always be relevant to the speaker/room interaction, and the listeners preferences.
In general, geometries will all be influenced by the above.
It is always interesting to hear or see the "generic audio" suggestions, like equilateral triangle, tweeter at ear height, toe in to on axis, etc, but in reality it can be a complex and time consuming exercise that can take years to get really dialed in.  In fact many of the generic offereings do not directly apply to VMPS.
Things like bass response, imaging, soundstaging, and so on all will depend on the placement, positioning, and convergence geometries you employ.
Even different VMPS models will be set up differently.  We have rear ported, monopole, folded baffle dipole, Dual Line Array Bipoles, Reduced Front Baffle, Side Firing Woofer, w/CDWG and wo/CDWG considerations, etc.
And when you factor in all the great tweaks that have been posted over the years, you have some very interesting and incredibly sounding systems and potential. :thumb:
