0 Members and 1 Guest are viewing this topic. Read 5943 times.
The damping factor does affect the control of the speaker, which is especially audible in the clarity and accuracy of the bass, because current is what does the work and bass frequencies demand the most power. This is why tube amps sound "warmer" in the bass, really they just don't have the ability to provide enough current to the voice coil to force it to follow the input signal.
Well, I confess to being even more confused than I was before I posted this. I love listening to music through good gear, but I don't understand . . . .
If you can compare two different amplifiers with an open mind and make a choice based on what you hear (not what you read), then you understand plenty.
Actually we provided this specification way back in the late 1970s with our famous Double 400 upgrade to the Dyna ST-400."Damping factor: Unit should not get wet"Regards,Frank Van Alstine
FirstWatt F1 and F2 (current source amps that only work in full range driver designs lacking speaker crossovers) and both of them had low output impedance as well.
