0 Members and 1 Guest are viewing this topic. Read 8993 times.
I auditioned both 2.4 and 3.7 earlier this week. Electronics used were a bryston 4bsst2 and an Ayon cd player with pre-amp section. I preferred the 3.7 although the price difference makes the 2.4 an excellent speaker. After the Bryston, we switched to an Ayon Spirit integrated tube amp. I preferred the tubes over the Bryston setup. Anyone else using tubes on Thiel?
I use the 3.7's with a Conrad-Johnson CT5 tube preamp and a Classe' 2200 amp. I've steered away from a tube amp 'cause I figured I'd lose the bottom end grip of the Classe (400 watts into 4 ohms..first 30 percent pure Class A). But I'm interested in Phil's Modwright choice. If I may be so bold, I'd like to suggest you try Shunyata Research's new Python Speaker cables...nothing has improved my beloved Thiel sound more than these cables. Well worth the price of admission.
Phil, How is the Modwright better than the very fine 14 BSST? Can you describe the difference? Do you not miss the power?
