Apple iGlazer
0 Members and 1 Guest are viewing this topic. Read 1187 times.
nathanm
Apple iGlazer
« on: 22 Mar 2011, 05:55 pm »
Just take a moment and try to take it all in.  I dare you!
If you are using more than one Mini DisplayPort to Single-Link DVI adapter, only two displays are supported across the three ports. To connect up to two Mini DisplayPort displays and up to a 30-inch DVI display simultaneously, use the ports without any adapters. To connect two DVI displays, use the dual-link DVI port and the Apple Mini DisplayPort to DVI Adapter or the Apple Mini DisplayPort to Dual-Link DVI Adapter (sold separately). To connect three DVI displays at once, you must use two Apple Mini DisplayPort to Dual-Link DVI Adapters (sold separately). To connect up to three VGA displays simultaneously, use the Mini DisplayPort to VGA adapter and DVI to VGA adapters (sold separately)
 :bomb:
skunark
Re: Apple iGlazer
« Reply #1 on: 22 Mar 2011, 06:40 pm »
And all I wanted to know is how to connect it up the composite input to my HDTV.   :scratch: :scratch:
 :lol:
guest4954
  • Guest
Re: Apple iGlazer
« Reply #2 on: 25 Mar 2011, 08:27 am »
In the Windows environment this would be called "plug and pray"
davidR
Re: Apple iGlazer
« Reply #3 on: 11 Apr 2011, 09:22 pm »
That's just "turrible".  :?
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: Apple iGlazer
« Reply #4 on: 12 Apr 2011, 01:26 am »
Makes complete sense to me... in terms of information they packed a lot of info into that paragraph.
dave
