Magnepan Woofers
0 Members and 1 Guest are viewing this topic. Read 3574 times.
  • The Demo is Everything!
    • http://www.bryston.com
Magnepan Woofers
« on: 22 Mar 2011, 05:32 pm »
Hi Folks,
I have a couple of these on the way to try with my MG1.7's.
http://www.magnepan.com/DWM_and_DW_1_Woofers
james
Ron D
Re: Magnepan Woofers
« Reply #1 on: 25 Mar 2011, 05:50 pm »
will be interested in your findings given both the woofers and your new mains spec out at similar low end frequency capabilities.
Might be the trick to "flesh out" a little more low end...
Please keep us posted!
« Reply #2 on: 25 Mar 2011, 06:21 pm »
Yes the idea is that even though they do not go much lower the woofer placement close to a boundary reinforces low bass and the smoothing affect of multiple woofers makes for a much better frequency response in the lower octaves.
james
rw@cn
« Reply #3 on: 25 Mar 2011, 07:27 pm »
james
I can understand the reasoning as one of the shortcomings of my 1.7's is that sometimes the low end seems a bit thin. But what about the frequencies below 40hz? I have a lot of music that utilizes that "last" octave.
I guess I need to listen before judging, but I remain skeptical that the Magnepan woofers will be a complete solution.
« Reply #4 on: 25 Mar 2011, 07:30 pm »
Yes i agree I have to try and see as well.
james
Ron D
« Reply #5 on: 3 Jul 2011, 06:31 pm »
its been a couple of months now, do you have any opinions on these speakers?
« Reply #6 on: 3 Jul 2011, 06:38 pm »
Hi Ron
I have not received the Maggie woofers yet - seems you have to know someone high up to get noticed :duh:
James
