Bogen DB 10-1 Mono "High Fidelity" Tube Amplifier - 1950'ish - good condition.
0 Members and 1 Guest are viewing this topic. Read 5599 times.
Bill Baker
    • Musica Bella Audio
I came across this nice little Bogen "High Fidelity" mono integrated tube amplifier and thought someone here might have a use or interest in it. If it doesn't move, maybe I will go through it and use it for some nice nostalgic tube sound :D
I believe it dates back to around 1950. Uses two 6V6 output tubes.
The amp and it's functions do work. I have not tested the phono circuits. I have done some general test on the bench but have not set it up with any speaker to actually listen to music with it. I would guess it could use some new tubes as all th etubes currently in it are all NOS and I have no idea how much time they have on them.
What you see is what you get. Pictures are of actual unit. I believe the warranty has run out :scratch:
Will obviously be sold as is.
Please submit any offeres via PM or email at [email protected].
Bill Baker
