0 Members and 1 Guest are viewing this topic. Read 3387 times.
G'day all, I don't think I've raised this subject here before, but in recent times I've completed successful construction of two more DIY ESP P99 sub bass filters that have gone on all of my already built ESP P06 phono preamps. I now think that sub bass filters are practically mandatory on phono stages, especially with 'ported' loudspeakers. I think they make a big difference (improvement). Any comments? Regards, Felix.
G'day mate, yes you're absolutely right. My little amp in here is only 15 watts per channel and there is no power available to waste in amplifying unwanted sub bass energy! Regards, Felix.
Subsonic filters are not necessary in a system that is properly set up. Furthermore, there is a LOT of subsonic information in many recordings, particularly classical, that is part of the performance or characteristic of the venue. Filtering the low frequency / subsonic information that is part of the recording subtracts from the performance or space in which it was recorded.
Some that have it make it optional on-off...which helps as you actually hear the difference with it on and off. Others design it into the circuit so it's there but you don't know it.
