V2 build from malaysia
0 Members and 1 Guest are viewing this topic. Read 13764 times.
jkelly
Re: V2 build from malaysia
« Reply #40 on: 11 Dec 2011, 05:27 pm »
I'm in - good project for Christmas vacation!
How big do the heat sinks have to be?
Jeff
kp93300
« Reply #41 on: 11 Dec 2011, 11:51 pm »
Hi Jeff
My heatsink is 10 x 2.5 x2.5 inches . After half hour it reaches about 60 deg c  at the output tran s --2n 3055. The teemp on the heatsink is only about 50 deg c.
I am in a tropical climate with ambient temp of about 28 deg c.
i describe the sound as very valve like but with the speed and control of trans
regards
kp93300
jkelly
« Reply #42 on: 13 Dec 2011, 12:11 am »
I am having trouble finding a heat sink like that for the TO3.
Let me know if you see any like that around with a flat surface
and then the fins.
Also how about speaker protection - if these short do they burn out
the speakers etc?
Jeff
kp93300
« Reply #43 on: 14 Dec 2011, 11:08 am »
and then the fins.
the speakers etc?
Jeff
I do not use speaker protection. I leave the amp playing with my test speaker for 2 hrs before I hook up to the mail speaker.
The amp  design is established and if there is no error or thermal runaway  there should not be any major problem.
I have a speaker protection unit that I did not use.
When you power down, there is a diminishing cracking sound .
2sc 3280 is a substitute for the 2n 3055 and is in T o 3 P .
regards
kp93300
