0 Members and 1 Guest are viewing this topic. Read 3687 times.
I doubt you will find a used tube preamp at that price with a decent MC preamp.
I would like to get some input from you guys. I need a tube Phono/Linestage preamp. Budget of 1K. I would like to stay lower than that, by a bunch if possible. Used is probably the obvious way to go with this budget. I listen to both Vinyl and CD. I have a Denon 103R moving coil cartridge. Here is the rest of my gear.VTL MB-125 monoblocksTechnics SL-Q3 turntableDenon 103R mc cartridgeVon Schweikert VR-2 speakers
First,I do not really know much about tube gear. I had been told that a SS per wouldnt work well because of an inpeadance mis-match with the Tube Amps. I trust and value your guys opinions.I am really just after great sounding audio on a poor mans budget.I guess I should be asking this.What would be a great Preamp setup for the VTL amps? Keeping in mind that I would need something to play the Denon 103R as well as CD's.
I saw a rogue 66 lsr on Audiogon. Missing the remote $550. What's the opnion on it?
