0 Members and 1 Guest are viewing this topic. Read 39100 times.
Hi Werd. I agree with your sentiments about hi rez. I personally don't buy into the theory I quoted but was merely plumbing for the technical counterpoint. I think there is something to "supra-sonic" information that is meaningful sonically much like there is with super tweeters. A second interesting question is "what do people think of upsampled, faux hi rez?" Better, worse....?
Barry and others, here is a piece of verbiage on this I have come across in the past and I thought I would throw it out there as a theoretical counterpoint to hi rez...
...Barry? Upsampling bad?
Barry and others, I have some other questions/observations:1. In regards to my performance of digital gear and power (logic behind Nordost article), have you found linear power supplies to improve computer and/or dac performance? A friend of mine who is on the hi rez train and owns the Amarra 4 dac (which is essentially what Barry owns) recently got a linear power supply for his mac mini and he was shocked at the improvement of the performance. In particular, he noted how the apparent gap between good redbook and hi rez (he has 24/96 up to 24/192) narrowed significantly to the point where the differences were marginal at best. It was as if more "information" was being extracted from redbook lending credence to the argument that there is enough data there for good performance.
2. Along the lines of redbook vs hi rez, what is there to be said about performance of specific chips? I have heard it said that performance of different chips can vary based on the resolution of the material. In other words, hi rez capable chips can adulterate redbook due to filters present and vice-versa.
Barry and others, I have some other questions/observations:1. In regards to my performance of digital gear and power (logic behind Nordost article), have you found linear power supplies to improve computer and/or dac performance? A friend of mine who is on the hi rez train and owns the Amarra 4 dac (which is essentially what Barry owns) recently got a linear power supply for his mac mini and he was shocked at the improvement of the performance. In particular, he noted how the apparent gap between good redbook and hi rez (he has 24/96 up to 24/192) narrowed significantly to the point where the differences were marginal at best. It was as if more "information" was being extracted from redbook lending credence to the argument that there is enough data there for good performance.2. Along the lines of redbook vs hi rez, what is there to be said about performance of specific chips? I have heard it said that performance of different chips can vary based on the resolution of the material. In other words, hi rez capable chips can adulterate redbook due to filters present and vice-versa.
In my opinion -- based on my experience with the high rez titles that I own -- the care given in recording, mixing, and mastering is much more important than whether or not a given title is delivered in 'high rez' to the consumer. (When I say 'mastering' here I'm thinking mainly of things like EQ and how compression is applied.)With the high rez titles that I own I am hard pressed to hear a clear difference in quality that I can attirbute to it being high rez. However, I own some standard 'redbook' recordings that make me completely forget that there is such a thing as high rez when I listen to them. I'll cite the MFSL remaster of Beck's "Sea Change" as one such title...absolutely exquisite...and I own the SACD version as well. Also, something like Steve Hoffman's remaster of "McCartney" is just so good that I can't really imagine it sounding any better.Granted, you could say that my system and/or my ears are not up to the task, but so be it. I'm just relating my experience.Joe
