Odyssey Audio Test CD: free download
0 Members and 1 Guest are viewing this topic. Read 10104 times.
Eduardo AAVM
« on: 13 Mar 2011, 07:56 pm »
For all those wanting to get this CD, which has clever and good tracks for an easy set up, it is my pleasure to tell you that it is available for downloading from Odyssey's website main menu, under the SERVICE tab.
It is a zip file with 15 numbered WAV format tracks and includes a xls file which has track listing so you can print it and use it in the CD jewel case.
Track 15 is great to set up stereo image, you should listen a continous, solid effect going from left to right and even at center the sound has to be present and real as if it is a center channel speaker.
Some have problems with main menu at Odyssey's web site, I haven't added the download link into alternative menu(2) as it implies modifying all pages, but you can download the zip here
rikhav
Re: Odyssey Audio Test CD: free download
« Reply #1 on: 17 Mar 2011, 05:46 am »
Hi
Very thanks for the link.
I think many will benifit from this test cd
dknywinnie
  • Music for Life
« Reply #2 on: 18 Mar 2011, 01:56 am »
The SERVICE link works on MS Internet Explorer but does not function on Google Chrome.
Eduardo AAVM
« Reply #3 on: 18 Mar 2011, 02:22 am »
Yes, as I said that menu is no 100% error free. Anywat check opening message and there is a link where you can download the file it says "here".
I will add this link ASAP to the alternative navigation menu on Odyssey's website
ttgolf
« Reply #4 on: 28 Apr 2011, 08:57 pm »
Thanks.
