Electronic Tube Puller
0 Members and 1 Guest are viewing this topic. Read 1833 times.
« on: 12 Mar 2011, 10:15 am »
Can anyone provide a link to a tool to help easily/safely pull the tube from my Eastern Electric DAC?
I would like to swap out tubes (or just be able to replace the tube when it finally goes).  I have limited experience with tubed gear, but the stock tube is really in there tight and there isn't room to reach to the sides/bottom of the tube (it's in a 3 cm x 3 cm deep recess).  The only way to get it out is to wiggle the tube back and forth by it's tip.  I'm afraid of breaking the tube and then having a real mess.  Plus I just spent $100 on exotic tubes and don't want the same to happen to them.
A quick check at Parts Express and bing showed nothing.
TIA
Charles Xavier
Ericus Rex
Re: Electronic Tube Puller
« Reply #2 on: 12 Mar 2011, 01:30 pm »
The tip can probably handle the stress.  After all, the glass at the tip is several times thicker than the walls of the tube.  Rock the tube back and forth while pulling on the tip and it should work out.  I don't know of a tool to help you with this.  Don't use pliers!  Best of luck!
