Other Stuff
Archived Manufacturer Circles
GIK Acoustics
Guidelines for ceiling diffusion or absorption?
0 Members and 1 Guest are viewing this topic. Read 2857 times.
slefley
7 Mar 2011, 05:22 pm »
Are there guidelines for ceiling treatments - diffusion vs absorption? I have GIK treatments on the walls, my speakers are Quad electrostatics in a 14' x 16' x 8' room, and I listen fairly near-field. Thanks for your suggestions.
bpape
Industry Participant
I am serious and don't call my Shirley
Re: Guidelines for ceiling diffusion or absorption?
7 Mar 2011, 05:29 pm »
Every room is a little different. Something like the Quads have a somewhat limited vertical dispersion so diffusion at the reflection points would likely not benefit you much.
That said, there are some issues with 8' ceilings that something like a pair of 244's over your head (not at reflections) would help.
Bryan
slefley
Reply #2 on:
7 Mar 2011, 06:00 pm »
Thanks - I'll try the 244s
Other Stuff
GIK Acoustics
