Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
What is the difference between the 5y3 and 6106
0 Members and 1 Guest are viewing this topic. Read 2485 times.
Jesuscookies
7 Mar 2011, 04:25 am »
Hello,
I recently purchased a Cornet2 off of audiogon. It came with both a 6106 and a 5y3. To my ears the 6106 is much more dynamic with better bass slam. However, are they considered identical tubes? Is there something that should be adjusted within the system to accommodate the 6106? I read something about adjusting B+ voltage, but I have no idea what this means, as I did not put the unit together, and really know nothing about DIY electronics.
Your help is greatly appreciated
poty
Re: What is the difference between the 5y3 and 6106
7 Mar 2011, 03:30 pm »
They are not differ much, so you can use the 6106 in the Cornet 2 without any modifictions.
Biff
Reply #2 on:
7 Mar 2011, 09:00 pm »
While we're on the subject of the rectifier...will a standard 5Y3GT (not indirectly heated) harm anything if used in the Cornet 2?
GRD
Reply #3 on:
7 Mar 2011, 11:33 pm »
In a word - no. I settled on the 5Y3GT after trying a number of other rectifiers. The B+ does come up quickly, in a few seconds, with a directly heated rectifier. But I've noticed no problems.
Biff
Reply #4 on:
8 Mar 2011, 02:58 am »
Thank you.
wdi
know just enough to be dangerous
Reply #5 on:
8 Mar 2011, 01:32 pm »
The Sovtec 5y3gt that Jim specifies in the parts list does behave differently from a typical 5y3. It takes 20 seconds or so (never really timed it) as opposed to 1-2 seconds that the NOS RCA 5y3gt I have takes to change the led from red to green.
Someone has previously pointed out that the resulting voltages are slightly different also.
Biff
Reply #6 on:
8 Mar 2011, 03:13 pm »
I went back to the slow starting Mazda 5Y3GB anyway. It sounds better.
Other Stuff
Hagerman Technology
hagtech
