0 Members and 1 Guest are viewing this topic. Read 4299 times.
The bearing and spindle are correct, ball bearing on the shaft, thrust plate at the bottom of the sleeve bearing. Yes black stuff should be cleaned out, and Wayne is correct it takes about a dozen Q-tips for me. I like to twist the cotton ends of the Q-tips a bit tighter to avoid leaving lint inside the bearing well, any alcohol will work. There should be a layer of cork on the bottom of the platter, they can get oil soaked and delaminate when people put way too much oil in the bearing well and it climbs up the shaft into the platter.With these non-inverted bearings the best lubrication is light weight machine oil. The 10W viscosity allows the lubricant to climb the bearing walls more effectively than heavier oils. This has been supported by techs at VPI in emails to me. However, it's a pretty non-critical application and almost any decent lubrication will work well enough as long as you clean it periodically and use enough fluid to create a proper oil bath in the bearing well. I have read internet theories that higher viscosity oils result in better sound, damping the bearing or something, untested by me.
I'm not sure about other tables, but if you go to a heavier oil than 20W in an AR, rumble goes off the charts. The belt doesn't like pushing, or dragging the extra viscosity...........viscosity and lubricity are not the same thing.
