Need parts list for new current recommended modifications of Cornet2
0 Members and 1 Guest are viewing this topic. Read 3084 times.
StylinLP
Hello all. This is my first post on the Hagerman forum. I ordered the Cornet2 phono preamp half kit and had machined the Altec Lansings silver case. Now I am about to order all the parts. I've been reading Wayne's and Tubesforever posts the last 2 years and see they are regularly experimenting and reinventing this kit. If I could get a parts order list it would help me immensely place these orders. I found the Russion caps on ebay but all the posts I read refer to differant specs. Below I copied teh digikey parts list. Could some of you refresh this list with the most current best replacement parts list and where to order them from? Maybe add a space under each line and highlight the replacement part :) BTW I tried going to Digikey and typing in these order numbers. None come up. That website is impossibly confusing to use. I can't even find the transformer this kit needs.
Help is much appreciated. Thanks
« Last Edit: 4 Mar 2011, 09:35 pm by StylinLP »
StylinLP
I managed to find some parts as listed with the original instruction manual. I'm still seeking better parts if anyone knows of any. I really need the resistors and cap upgrades that Tubesforever and Wayne used.
Component       Qty     Digikey
47uF 450V         5        493-1461-ND C103, C201, C207
10,000uF 10V    3        493-1275-ND C106, C209, C210
470uF 10V         2        493-1269-ND C205
0.1uF 50V          2        EF1104-ND C102, C211
1uF 400V           6        PF4105-ND C200, C206, C208
      C208 - Mundorf Silver/Oil 1uF bypassed with a Russian Teflon Capacitors FT-3 0.1uF 600V (eBay)
      C200 & 206 - Sonicap Gen1 1uF 600VDC
      C203 - Sonicap Platinum .1uf 400VDC
      C202 - Sonicap Gen1 47nF 600VDC
      C204 - Sonicap Gen1 1nF 600VDC
0.1uF 400V        2        PF4104-ND C203
47nF 630V         2        P3517-ND C202
1nF 630V           2        P3497-ND C204
0.01uF 2kV        2        P11423CT-ND C100, C101
LED R/G           1        160-1715-ND D100
     Lite-On Inc - LED 5MM RED/GRN BICOLOR DIFF - 19mcd Green, 5.6mcd Red
1N5821              4        1N5821DICT-ND D101, D102, D103, D104
       Diodes Inc - DIODE SCHOTTKY 30V 3A DO-201AD 500mV @ 3A Fast Recovery =< 500ns, > 200mA (Io)
Grommet         10*       RP456-ND
Power Cord       1         Q120-ND
Heat Sink           8        HS372
     Aavid Thermalloy - HEATSINK TO-220 VERT MNT W/TABS Bolt On and PC Pin Aluminum
Feet                    4        SJ5523-0-ND
Standoff #4x1” 10*     4806K-ND
Fuse                    2       F2419 F100
Dome, LED        1       L30032-ND
Grounding Post   1       J587-ND
RCA-2                2       CP-1435-ND J200, J201
      CUI Inc - CONN RCA JACK DUAL R/A RED/WHT - Digikey
      Jack - RCA Chassis Mount, Front Mount, Gold Plated, White - S-H267W - Tubeandmore.com
      KIMBER-53448 - Female jacks, chassis mount - mounting hole 0.5" (1/2") PAIR
       partsconnexion.com
AC Input             1      CCM1647-ND *there has to be a better high end option that this*
      Tyco Electronics - MODULE POWER ENTRY 10A W/SWITCH 250VAC Panel Mount, Snap-In
Fuse Holder        1      WK0011-ND
Terminal           30      1285K-ND
Crimp               30      A27804-ND
Switch, Mono     1      360-1791-ND S200
     NKK Switches - M Series, Angle PC Mount Toggles - 0.4VA @ 28VAC/DC - Digikey
2N3906               2      2N3906FS-ND Q100, Q101
      Fairchild Semiconductor - IC TRANS PNP SS GP 200MA TO-92 PNP 100 @ 10mA, 1V
2SC3942             2      2SC3942-ND Q200
      Panasonic - SSG - TRANS NPN HF 300VCEO .1A TO-220F NPN 50 @ 5mA, 50V
Resistors:
PRP was recommended but what values?
PR9372 Audio “Metal Film” 1 Watt Resistor – 1%, 100ppm - partsconnexion.com
220 1W             20      220W-1-ND R101, R102, R103, R201, R208,
                                    R212, R214, R216, R217, R219
680 1W               5       680W-1-ND R104
910 1W             10       910W-1-ND R203, R210, R215, R218
1.8k 1W              5      1.8KW-1-ND R220, R221
3.3k 1W              5      3.3KW-1-ND R213
6.8k 1W              5      6.8KW-1-ND R100, R106, R108, R205
10k 1W               5     10KW-1-ND R105, R204, R211
47k 1W               5     47KW-1-ND R200
150k 1W           10     150KW-1-ND R202, R207, R209
330k 1W             5     330KW-1-ND R107, R206, R222
1.8 5W                1     1.8W-5-ND R223
Socket, 8-pin       1     P-ST8-193G
    Socket - 8 Pin Octal, Ceramic, PC Mount, Gold Pins  - Tubeandmore.com
Socket, 9-pin       3     P-ST9-214G
    Socket - 9 Pin, Miniature, Ceramic, PC Mount, Gold Pins - Tubeandmore.com
Transformer        1     P-T370BX T100
    Transformer - Hammond, Power, 275-0-275 V, 50 mA - Tubeandmore.com
Which tubes are the best to try out first?
12AX7                2     12AX7 V200, V201
      Tung-Sol 12AX7 Reissue - Russian made - Tubeandmore.com
12AU7                1     12AU7 V202
       JJ Electronics 12AU7/ECC82 dual triode, with gold pins - Tubesandmore.com
5Y3GT                1     5Y3GT V100
      Sovtek 5Y3GT full wave recitfier - Tubeandmore.com
Screw #10           1*     P-H245
Nut #10               1*     S-HHN1032
Washer #10         1*     S-HLW10
Screw #4              3*    S-HS440-14
Nut #4                  2*    S-HHN440
Lug                       1*    S-H112
« Last Edit: 12 Mar 2011, 06:06 am by StylinLP »
WGH
Sorry, but I'm way too busy to go through the Cornet2 parts list to find the current parts numbers for you.
As for cap upgrades I bought mine through Sonic Craft http://www.soniccraft.com/
Use "Search" in Hagerman Technology and you will find most of your answers. What search terms? Try:
Mundorf
Sonicap
Russian Teflon FT-3
Resistors
Cornet2
Everything will make sense after a while, there is a learning curve.
Wayne
poty
You are welcome!
IMHO you have done the biggest part of the job.
I suggest to build as close to the original (parts list) as possible! Boutique and other exotic parts could be tricky to find and use and won't give you any better results until you understand the nessesity and "taste" of each change.
It seems in the Digikey all is organised the easiest way. In the line "Part Search" enter the part number (for example, 493-1461-ND) and press "go". The page for the part number will be opened then. (http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=493-1461-ND+&x=26&y=29)
After that, to look at another part (for example, 370BX-ND), enter the new part number at the line "Keywords" and press "Search Again". The new page (http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=370BX) will open...
bregez
I would also stay with the list provided from Hagtech.  One recommendation I would make would be using EH 12AU7's in place of the JJ's.  They seem to be more linear in this particular application.
StylinLP
Thank you guys for the help so far. I saw the reason I couldn't find alot of the parts on Digikey was because I was looking for Tubesandmore parts there. Got that straightened out.
I figured resistors are an easy thing to substitute. No reason to re-invent the wheel. I've read and was told that PNP resistors are amazing along with Vishays. Im not sure if a few "key" resistors would be better with a certain brand and value. I read that on here somewhere. I guess I will try to track it down and see if the info is complete for me to make an order.
ABout the Caps I will do some more research before posting about them again. THanks Help is much appreciated.
SC50
In order to get my voltages correct I ended up using a 1.3 5W in R223 position,if I recall correctly. You might consider ordering some smaller values just in case- cheaper to do it all at the same time.
