New soldering iron.
0 Members and 1 Guest are viewing this topic. Read 2050 times.
rajacat
  • Washington State
New soldering iron.
« on: 1 Mar 2011, 07:25 pm »
Is it worth the extra $ to get a soldering station for lead free solder? I'm considering this one.http://www.circuitspecialists.com/prod.itml/icOid/9752
or http://www.circuitspecialists.com/prod.itml/icOid/10359
I like the hot air option for SMD and specifically replacing op amps which in my DAC are very small and with very close quarters connections.
Roy
sts9fan
Re: New soldering iron.
« Reply #1 on: 1 Mar 2011, 07:56 pm »
Those look cool.  One day i will upgrade my bottom rung station.  I just have not found the need.
AVnerdguy
« Reply #2 on: 1 Mar 2011, 08:02 pm »
Thanks for the link. I've been looking for a new iron. I bought a so so temp control unit to replace my (very old digital) Weller and am not satisfied at all. Since they went to the new environmentally safe solder (insert sarcasm here) I just can't get the temps constant enough. Any experience with these? I think I'll take the plunge - just curious.
avionic
« Reply #3 on: 2 Mar 2011, 06:48 am »
They sell a very nice product.I have one of the now discontinued stations(2A) and like it a lot. I really like the first one that you linked.
rajacat
  • Washington State
« Reply #4 on: 2 Mar 2011, 06:57 am »
I do think I'll go with the first one and continue to use mostly leaded solder. I especially  like the clamp that holds the hot air iron leaving your hands free to use tweezers or pliers to remove a tiny part.
-Roy
