MFW15 Cutout Dimension
0 Members and 1 Guest are viewing this topic. Read 1587 times.
Zhillsguy
« on: 1 Mar 2011, 01:09 am »
Does anyone have an accurate cutout dimension for these drivers?
Z
Danny Richie
Re: MFW15 Cutout Dimension
« Reply #1 on: 1 Mar 2011, 01:54 am »
Z
I believe the through hole is supposed to be 14", but my measurements should it closer to 13.875"
And welcome to AC!
Zhillsguy
« Reply #2 on: 3 Mar 2011, 04:12 pm »
And welcome to AC!
Thanks Danny.........received the driver here in Zephyrhills 3 days after calling you....it is a thing of beauty, and definitely deal of the year.
I will do some test holes in the next week or so and post my results. I like the driver to fit tight, about 1/16" larger than the driver frame.
EDIT: I did a test hole at 13-13/16", fit good. The driver frame is probably 13-3/4".
« Last Edit: 4 Mar 2011, 09:51 pm by Zhillsguy »
alienderivative
« Reply #3 on: 9 Apr 2011, 01:42 pm »
I cut the hole conservatively and at 13.5", I still have a way to go before it will fit.
