Marantz 6300 dust cover (another dumb question)
0 Members and 1 Guest are viewing this topic. Read 8718 times.
markmark
« on: 28 Feb 2011, 07:22 pm »
I'm looking for a dust cover for my Marantz 6300 turntable.
Can anyone confirm or deny if any other Marantz dust cover will interchange? I'm looking at a 6200 for a good price & want to check before I make an offer.
Mark
Wayner
Re: Marantz 6300 dust cover (another dumb question)
« Reply #1 on: 28 Feb 2011, 08:44 pm »
Because the tooling for a plastic injected molded dust cover is quite the expense, my guess is that it will fit across the whole series. I just bought a dust cover for a Sony PS-x30 that fit my PS-X7. I would ask the seller what the dimensions are and what centers the hinges are on to be safe.
Wayner
orthobiz
« Reply #2 on: 1 Mar 2011, 12:13 am »
All dimensions different. Will not fit. Vinylengine.com has the exact numbers for each, check out the library there.
Paul
markmark
« Reply #3 on: 1 Mar 2011, 02:04 am »
Thanks guys.
Orthobiz is correct. When I asked the guy about measurements, he said the same thing.
Thanks again,
Mark
rcag_ils
« Reply #4 on: 1 Mar 2011, 02:11 am »
What was expensive in the U.S. might not have been expensive in Japan, that's why early Marantz was designed in the U.S. but made in Japan.
The experience I had with Japanese interchangeable parts were, the Japanese made sure that they made every little parts different in the same series, so you had to go to them to get the right parts, that's business.
neobop
  • BIRD LIVES
« Reply #5 on: 1 Mar 2011, 02:28 am »
You can get a new cover, made to orig specs, but it will cost $130 to $150 incl ship.
I got one and it's nice. All you need is the hinges.
http://www.turntabledepot.com/home.php
BikeWNC
« Reply #6 on: 1 Mar 2011, 02:39 am »
I have a dust cover for a Marantz 6300 that you are welcome to have for the cost of shipping.  Just let me know.  In fact, I have a 6300 without a tonearm you can have with it if you want to pay for the extra weight.
Andy
Wayner
« Reply #7 on: 1 Mar 2011, 03:38 am »
Well, that's complete BS. I have several brands of TTs from Japan that have many inter-changeable parts. Many Technics tables are like that, as my SL-Q2 has a dust cover from a belt drive SL-220. Other then the badge on the top, they are the same. My Sony's are also exact from the PS-X5 and the PS-X7 and I have seen many other table brands that have interchangeable covers, my PS-X7's cover was broken and it has one from a PS-X30. I paid $30 for it, shipped and it's like brand new.
My advise to people looking for dust covers is to check for like series of tables. You maybe lucky enough to find a match and not have to pay $90 for it like the guy on eBay charges and these are fabricated covers that are made to fit, but not like the original molded covers.
You do have to check for size, but you may get lucky. Why Marantz made even their same series of tables (finding out later) different, is anybody's guess.
W
markmark
« Reply #8 on: 1 Mar 2011, 11:37 am »
Andy,
Yes on the cover.
I'll try to get in touch with you
orthobiz
« Reply #9 on: 1 Mar 2011, 04:45 pm »
Tubby thing is the numbering system...the 6300 direct drive not part of the 6100/6200 belt drive line.
Paul
iPad my bad: I meant "funny" not "tubby"
« Last Edit: 3 Mar 2011, 06:35 pm by orthobiz »
Wayner
« Reply #10 on: 1 Mar 2011, 06:55 pm »
My bad. I thought the 6200 was also a direct drive. It's odd that none of the marantz TTs seem to follow a design pattern, making me wonder if they actually built them or had different companies build for them (badging them marantz). Who knows.
Wayner
wintin82
« Reply #11 on: 22 Dec 2013, 05:36 pm »
Is the dust cover still available for the 6300, I can't seem to find one anywhere but flea bay.
