Cornet2 only working on one channel
0 Members and 1 Guest are viewing this topic. Read 1589 times.
Lengy
« on: 27 Feb 2011, 03:00 pm »
After fitting two new 12AX7 tubes yesterday, my cornet2 stopped working on the right channel.  I have swopped the tubes over and the fault is still on the right channel, I did a quick voltage check and the right channel is very high (254v) at R204r.  When I fitted the tubes the board could have flexed and damaged a track or joint, but I didn't hear or feel anything unusual, does anyone have any ideas?
Lengy
GRD
Re: Cornet2 only working on one channel
« Reply #1 on: 27 Feb 2011, 04:06 pm »
A little more information needed.
What tubes did you swap?  Did you switch the new AX7's between V1 and V2?  Could still be a bad tube with one channel not working.
Or did you put back the original AX7's that were known to be good?  Then likely not a tube.
Voltage reading at R204 indicates low or no conduction through V200, which could be the tube, or the connection from the tube through 203 to ground (assuming R203 is OK - easy to measure the resistance to confirm).
Hope that helps.
Lengy
« Reply #2 on: 27 Feb 2011, 07:40 pm »
It was the valves, does that mean that the valve has blown in the amp on start up or it was faulty when purchased?
poty
« Reply #3 on: 27 Feb 2011, 10:05 pm »
I don't think it is from the power on disturbances.I would very surprised if it is from that. I think there could be either bad tubes or maybe some pecularity in pins design of the tubes.
It just comes to my head - are the tubes definitely 12AX7? Maybe the pins layout is different (because of different type of tube)?
GRD
« Reply #4 on: 28 Feb 2011, 02:26 am »
Lengy,
Sounds like you're up and running now.  I'm with poty - turning on the Cornet wouldn't cause a good AX7 to fail.
Grant
hagtech
« Reply #5 on: 9 Mar 2011, 05:10 am »
Most of the time it is an interconnect - external to the phonostage.  Always swap cables between channels first when debugging.
jh
