SOLD Luminous Audio Axiom Signature Passive Preamp SOLD
0 Members and 1 Guest are viewing this topic. Read 2137 times.
neilwill
Up for sale is the Luminous Audio Axiom Passive Preamp.  This unit is in excellent condition.  It is the signature model with the upgraded Caddock resistors.  This is the 2.5k version.  My price is $100 shipped.  See pics and read manufacturer writeup below:  SOLD
The AXIOM is a truly reference quality preamp in an inexpensive enclosure. This is a fixed series/variable shunt device. In layman's terms this means the signal does not actually flow through the volume control. The signal flows through one high quality resistor and the amplifier's inputs are shunted to ground via the AXIOM’S Noble potentiometer. The degree in which the pot “allows” signal into the amplifier is simply what allows the customer control over his/her volume. A large part of the magic of the little AXIOM is its single input. We use no switching network whatsoever. Most critical listening is done on CD playback so why not shoot for the ultimate in clarity. The variable shunt technology allows control over the volume without the signal flowing through the actual volume pot which most audiophiles know is the weakest link in most preamp circuits. We are using very high quality custom made RCA’s with long barrels. A smooth NOBLE pot was chosen for long life, excellent tracking and a concern for cost vs. value. We are using the same 4/9’s silver wire found in our famed SYNCHESTRA interconnects. We are allowing our customers to choose between the standard HOLCO resistor and the upgraded CADDOCK version. The CADDOCKS are simply the best I have heard in this circuit. Considerably more detail than the HOLCO but for many applications the HOLCO will work very well. We invite you to compare the AXIOM to any preamp on the market. It will not be embarrassed by anything at any price.
« Last Edit: 27 Feb 2011, 04:46 pm by neilwill »
