0 Members and 2 Guests are viewing this topic. Read 4641 times.
Is replay gain bit-perfect? Or does it reduce bits to reduce volume?
I don't have replay gain set in any of my library. I generally don't notice any problem listening to an album straight through but I have a number of mix-type playlists I've made where the volume changes can be quite jarring. Will replay gain fix my problem? I'm using the Squeezebox software.
How bout the volume control on the SB3, degrades sound?
