Two-channel applications with Denon 3803
0 Members and 1 Guest are viewing this topic. Read 1060 times.
sjeb
« on: 24 Mar 2004, 12:05 am »
Does anyone know if the Denon 3803 when set to the Pure Direct or Direct mode (or otherwise) applies any processing to an analog signal coming into the CD input? I know signals to the Ext. In inputs are not processed, but was wondering if you could also connect a second stereo component that way.
Thanks.
Sarkis
Rob Babcock
« Reply #1 on: 24 Mar 2004, 12:24 am »
In direct mode the analog signal is still re-digitized.  You're better off using the digital input or the ext inputs.
