Torus 240V conditioner on circuit as inwall air conditioner: possible OK?
0 Members and 1 Guest are viewing this topic. Read 1483 times.
Elizabeth
I have a 240v outlet at the wall right where it would do for having a 240V in Torus. To use for my Bryston 4B-SST2.
So.. my question is: can I use it for both the air conditioner (an average size room 240V job) AND the Tarus?
The circuit breakers for this outlet are a pair of 15 amp each jobs
Since the air conditioner is on only during three months of the year, and running full time only in August, is it OK?
Added: I cannot find any info from Kemore (Sears) about the electrical requirements for the air conditioner. On the website, and in the owners manual NO info on peak power consumption. the ONLY comment is a energy star rating of 9.5 big help hey.
Inquiring minds want to know?
My idea is to use a 240V Torus with a balanced 60/60V  output for the Bryston amp. and preamp.
 :banana piano:
srb
If the BTU rating is on the unit, you can probably get a better idea, but most 240V window AC units in the 8,000 to 10,000 BTU range have very similar specs - they require a 240V / 15A circuit, have an EER of ~ 9.5 and consume ~ 5A in normal operation.
However, they will draw more amperage for a number of seconds when they are turned on and when the thermostat cycles them on and off, and can also can cause a slight voltage drop depending on the type and condition of the compressor.
As the Torus conditioners don't provide voltage regulation (I don't think), this might present a temporary performance loss and it's also possible for the compressor and fan motors to induce some noise on the circuit, although the Torus may filter it out.
You probably wouldn't likely trip the circuit breaker when it cycles on and off, but local codes often require that the circuit is dedicated and not shared with other devices.
I had previously searched for a 240V plug-in power meter similar to P3's 120V Kill A Watt units, but was unable to find any.  A clamp-type multimeter could provide the voltage and current measurements, but are quite a bit more expensive if they have the capability to record low or peak values.
werd
You might want to look at the wiring first. The Torus use only 2 - 120 hots and a ground. That air conditioner might have a neutral hooked up to it?. That would be 2 hots and a neutral and a ground. That outlet could still be used but you might need to drop the neutral and dedicate it to the torus. The outlet might not fit the torus because of this.
Elizabeth
The wiring is the two hot 120V legs and a ground. No neutral.
I would just make a box with two outlets with a pigtail 10 gauge wire+ plug to the wall and plug the air and Torus in to the box.
The wall has a singleton 240 round socket.
werd
Sounds like a plan Elizabeth  :thumb:.
