How can I check if my Mac Mini performed a bit perfect...
0 Members and 1 Guest are viewing this topic. Read 1491 times.
Dracule1
import of my CD into the hard drive?  I'm having issues with severe vibration and noise when I import CDs and was wondering if the problem can affect copying.  Thanks.
JeffB
Re: How can I check if my Mac Mini performed a bit perfect...
« Reply #1 on: 22 Feb 2011, 12:09 am »
Hopefully somebody will have a better answer than this.
I don't have a Mac so I am not sure about this.
Unix boxes have a command line tool called "diff" that will compare two files.
diff fileA fileB
The trick will be specifying the file on the audio CD.
I don't know how to do this for a Mac.
You might have to rip it twice and then compare the two results.
skunark
« Reply #2 on: 22 Feb 2011, 12:28 am »
RIP: http://sbooth.org/Rip/
XLD: http://tmkk.pv.land.to/xld/index_e.html
In addition to all the error-correction that cdparanoia (and other libraries offer), both of these will generate a checksum to compare on an online database.
I've used RIP and felt it did a great job even though it's still considered 'beta' by the author.
(updated URL for XLD)
« Last Edit: 22 Feb 2011, 02:51 am by skunark »
NastyChipmonk
« Reply #3 on: 22 Feb 2011, 02:25 am »
Mines noisy and vibrates and is 5 years old. Never let me down. CD drives always parity check so I wouldn't worry. If the rip takes a long time, then the drive is retrying, and then if it says it failed, it failed. If it says complete with no errors, then you are good to go.
Dracule1
« Reply #4 on: 22 Feb 2011, 02:28 am »
Thanks for the info everyone.
