No Regrets
0 Members and 1 Guest are viewing this topic. Read 3073 times.
Deftone
No Regrets
« on: 21 Feb 2011, 10:34 am »
Really like my 4bsst2,BP-26/Mps2,Bda-1 and Bcd-1.It took my b&w 803s to the next level.I wonder the 7b will be a thousand times better.But due to the room size i have to live with the 4b for time being.
By the way I am using the stock power cord and i am in the market to upgrade the power cords.Any suggestions?
Elizabeth
Re: No Regrets
« Reply #1 on: 21 Feb 2011, 11:36 am »
Hi, I have the Bryston 4B-SST2 and BP-26 plus the phon 1.5 setup.
I use Pangea power cords. They are a very good value, (low priced too) and the (only) place that sells them does have a thirty day 100% refund. Audio Advisor. (Be aware the thirty day is firm, no exceptions after thirty days from purchase date)
But they are a very good cord. You may notice better bass straight up. One thing, get at least a 1+1/2 meter or two meter if buying the '9' size cord, as it is stiff torsionally, and the shorter ones can be hard to rotate the connectors to stay in the A/C receptical on the one meter or 0.6 meter cords.(if they happen to not line up naturally)
So the 9 for the amp. and some 14SE for the pre and other stuff (if you go for several). I love them.
redbook
  • the music is the blood...........
Re: No Regrets
« Reply #2 on: 21 Feb 2011, 11:45 am »
I found the same with the Nordost Vishnu. The highs are smoother as well.
Robert D
Re: No Regrets
« Reply #3 on: 21 Feb 2011, 01:40 pm »
Elizabeth
Where can the power cords be purchased... I'm in Montreal
Robert ty
Phil A
Re: No Regrets
« Reply #4 on: 21 Feb 2011, 01:46 pm »
Laundrew
Re: No Regrets
« Reply #5 on: 21 Feb 2011, 03:40 pm »
...I wonder the 7b will be a thousand times better.But due to the room size i have to live with the 4b for time being...
Greetings Deftone  :D
I believe that once you attain a certain level in audio equipment, you do not really notice a huge difference in audio quality from one model to the next one. For example, the 28B SST² does not stand “head and shoulders” above the 7B SST² in audio quality. You do receive extra subtleties in your music with the beasties and what an individual must decide if this is worth double the cost of the 7B SST² amplifiers.
Also let us not forget about the vanity factor. :wink:
Be well...
werd
Re: No Regrets
« Reply #6 on: 23 Feb 2011, 05:17 am »
Hello Deftone
Check out Wywires juice 2 power cables. They work really nice with Bryston gear in all components. Including digital, and power. They are very reasonable at 239.00. I just bought one for my bdp1.  :thumb:.
Deftone
Re: No Regrets
« Reply #7 on: 23 Feb 2011, 11:03 am »
I am still auditioning for the after market power cords.Already did a few.I am also looking at the U.K. type for the plug.Pangea don`t come with it.Nordost do.The local dealer where i am from don`t have the Vishnu.
Robert D
Re: No Regrets
« Reply #8 on: 23 Feb 2011, 12:24 pm »
http://www.audioadvisor.com/products.asp?dept=25&pagenumber=2&sort_on=title&sort_by=
Thank you Phil
How do these power cords compare to the Bryston standard power cord ?
All of my Bryston gear is plugged in to my RM20 .
Would there be that much of an improvement ???
Robert
