4bsst2 current draw?
0 Members and 1 Guest are viewing this topic. Read 1964 times.
jaxwired
« on: 20 Feb 2011, 04:29 pm »
How much current does a 4bsst2 amp pull during normal operation. I can find this stat for the big 28b on the Bryston web site, but I cannot find the similar stat for my 4bsst2 amp.  The 28bsst2 draws 9.5 amps.  Anybody know the answer?  Thx :)
jaxwired
Re: 4bsst2 current draw?
« Reply #1 on: 26 Feb 2011, 04:30 am »
Since quite a few people have viewed this thread I thought I'd go ahead and answer my own question (now that I know the answer).  The 4bsst2 will draw 7amps at full output.  7 amps max draw.
Alpha10
« Reply #2 on: 26 Feb 2011, 08:39 am »
Is that 7 Amps at 120 or 240 Volts??
Cheers
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 26 Feb 2011, 12:06 pm »
Cheers
Hi
120V
james
Elizabeth
« Reply #4 on: 26 Feb 2011, 01:04 pm »
Thanks, nice to know. Not that i ever use more than a few watts output from my 4BSST2! But good to know if i ever decide to 'break my lease'. LOL!
Alpha10
« Reply #5 on: 26 Feb 2011, 03:09 pm »
Hi
120V
james
Thank you James, I was just a little surprised at how low the current drawn was, I am sure I had read somewhere that you should only run the 4BSST2 and above from a dedicated spur due to their demand, but that seems fine, especially with our UK 240V?
Cheers
