Lip sync issue connecting to cable TV box analog outputs?
0 Members and 1 Guest are viewing this topic. Read 1088 times.
rockadanny
In my quest for an inexpensive solution to crappy TV sound I am at the point where I am considering T-amp and bookshelf speakers (dislike soundbars and Zvox box is too large). Since TV has only one audio output - optical - I was considering tapping off the cable box (Comcast) RCA outputs. But now I read that some people have had audio (lip) sync issues doing this, though not specifically with Comcast. (Audio and video out of sync.)
What would cause such a thing?
Also, do you know if I might have this issue were I to connect to the optical audio out of the TV instead? I was avoiding this solution as I'd have to buy a converter (optical-to-analog) to do it this way.
Phil A
Re: Lip sync issue connecting to cable TV box analog outputs?
« Reply #1 on: 20 Feb 2011, 01:45 pm »
I sometimes have an issue with the kitchen TV where I got a digital video (over-the-air) signal and it is broadcast in Dolby Digital and I have it converting to just the TV speakers as that's all that is hooked up to it.  So I'd guess you have a similar thing going on where you have audio and video delivered by different means.  I'm not sure a converter box will resolve the issues.
