6V4 vs. 6CA4
0 Members and 1 Guest are viewing this topic. Read 4094 times.
denny9167
6V4 vs. 6CA4
« on: 20 Feb 2011, 04:47 am »
I'm needing a 6V4 for an FM-1 rebuild,but I have a pair of 6CA4 tubes that are very similar in design,I do know they draw more heater current,and take a larger input capacitance. Will this tube work in it's place?
Bill Thomas
Re: 6V4 vs. 6CA4
« Reply #1 on: 20 Feb 2011, 04:50 pm »
Denny,
Considering the cost of a new 6V4/EZ80 is *usually* well under $20.00 for a GOOD quality NOS tube, I would avoid trying to substitute a 6CA4 in its place.  The additional filament current will increase the load on the Power Transformer significantly.  Since new Power Transformers for the FM-3 are non-existent, this seems like "false economy" to me.
This is ESPECIALLY true if your FM-1 has the Multiplex module installed.  The 6CA4 will push the load on the Power Transformer beyond its normal loading.  As you know, heat is the enemy of the FM-3.  The additional load of the 6CA4 will make things even hotter.
Bottom line:  I would hold out for a 6V4/EZ80.
Make sense?
Bill Thomas
denny9167
Re: 6V4 vs. 6CA4
« Reply #2 on: 20 Feb 2011, 08:24 pm »
Denny,
Thanks Bill, I have other uses for the 6ca4's so it won't be a problem.
Make sense?
Bill Thomas
denny9167
Re: 6V4 vs. 6CA4
« Reply #3 on: 2 Mar 2011, 12:41 pm »
Denny,
Make sense?
Bill Thomas
Would there be a way to put a series resistor in the filament curcuit,to limit current draw,would this effect the 6ca4's output?
baldrick
Re: 6V4 vs. 6CA4
« Reply #4 on: 4 Mar 2011, 01:14 am »
If you limit the current on the filament you won't get proper heating of the cathode...
If you want to use a 6CA4 then you'll need a small filament transformer.  There may be enough space below the chassis for one.
But you can get current production 6V4s which are just as good as NOS:http://thetubestore.com/nos-6v4.html
denny9167
Re: 6V4 vs. 6CA4
« Reply #5 on: 4 Mar 2011, 03:07 pm »
I thought that might be the case,but wanted to make sure,thanks
