0 Members and 1 Guest are viewing this topic. Read 7844 times.
Hi Ozark,You had that one rigged didn't you? Just because you had the one decent digital recording that sounds better on a tube player, than a particular cartridge, doesn't prove much. You knew in advance that it would be so. I was never partial to those cartridges myself, and I suspect it's just that combo and recording that gave you the opportunity you're bragging about. You must admit, that is not the norm. Why do you think the faces turned red? They weren't expecting that, because it's usually the other way around. You are/were not much of a high end dealer if all you offer is Koetsu carts. Maybe that's good though, for the Ozarks, I wouldn't know. BTW, this happens to be the vinyl circle, if that digititus has you disoriented. Are you sure you want a pissing contest? Regards,neo
No P contest, never meant to rustle any feathers. A not so well known trade secret, try an AR ES-1 turntable from the 80's with your vinyl. One of the best imaging and soundstage you will efer hear with your LP's. It beat all those other tables I mentioned plus the Oracle and Pink Triangle. Since it came from a mid-fi company, the audio mags shunned the ES-1.But to hear a master tape? That is a huge improvement over both LP and CD. That makes you want to throw the other two formats away.
Tom, yer store was in Kansas City, right? You ever sell Eminent Technology speakers? If I remember right, the AR was a suspended design, right? My next door neighbor in fabulous Fort Worth, Texas had one. He used to get my hand-me-down high output cartridges. Can't remember, was that headshell removable? The one it came with made cartridge alignment a tough propostion if memory serves.Thanks, Wolf. Just beautiful.
Ya ought to hear one that has been through a complete revision.......where all the "issues" have been corrected. And with a decent Grado dragging on it.A simple drop in piece will take a THE TURNTABLE to the level of a stock ES-1........and since this is a SRV thread........I took that ES-1 to a stereo store. The Hi-End room didn't have any analogue equipment.....so i brought my Preamp as well. They had just gotten AYRE amps in and were breaking them in on Couldn't Stand the Weather. One of the salesmen had never heard vinyl.The owner (friend of mine) just threw his hands in the air and walked out.The kid, when he finally got his mouth shut....uttered something like S#@T!!!!!Flat out smoked that CD.
