0 Members and 1 Guest are viewing this topic. Read 21670 times.
JT,What dac are you using with your Mac Mini and how are you connecting to your dac?
My 2009 Mini beat my SB by a long shot. The mini was bone stock with the least amout of RAM and NO SSD. There is absolutely no comparison IMO.
What kind of PS was powering the Touch? Any mods?
Great topic. I have a Touch & have considered a mac mini. Is there a diagram/drawing/picture somewhere to get a visual of how a system would work w/ it, in lieu of the Touch/
See my above post and this one. This is my iPad in front of my T.V. Same thing...
Thanks. So if I used an iPad, iPod Touch, or IPhone, would I still need a monitor? How much do Mac Mini's go for now? Just thinking how I could go the lowest cost initially and then add on if I care to later. Most appreciated.
I've read (Stereophile article, I think?) that it might be possible to use the Touch's USB to feed into a DAC. Has anyone heard this and if so, how did it compare to a Mac Mini?
Just wondering - how would a Squeezebox Touch(modded or not) using a decent linear power supply fare against a Mac Mini with modded PS? Let’s say both were using the same DAC (Eastern Electric for example) and the Mac was connected to an AudioPhileo 2 or other similarly priced USB-S/PDIF converter.
You'll at least need a monitor to set up your Mac Mini in the first place. But after that, you could go headless and control everything from your remote (e.g. iOS device). But if you ever needed to change configurations or something, you'd need to hook up a display again.A brand new Mac Mini MSRP is $700.
