what happened to the "sticky" outlining the details of the amplifier upgrades...
0 Members and 1 Guest are viewing this topic. Read 1166 times.
Ron D
by serial number/by model?
Did it get moved, did I miss something here?
  • The Demo is Everything!
    • http://www.bryston.com
Hi Ron,
It was not being accessed very much so it is just in the main body now.
james
Ron D
thanks James!
I thought it might contain the info regarding the most earliest of 14B-ST amps. I was looking to confirm that while its been noted that all 14B-ST amps were in fact SST amps I thought that the very earliest versions were 500 w/ch and very soon became 600 w/ch and if that was correct at which serial number this took place.
thanks James!
Yes there was a very minor change in the transformer early on which upped the power a little - not that you would notice sonically :D
james
