AKSA 55 Nirvana Setup.
0 Members and 1 Guest are viewing this topic. Read 2205 times.
Grumpy_Git
« on: 29 Jan 2003, 11:40 pm »
I've finished my 55 (nirvana'd straight off) and I've begun the setup proceedure.  :P
Using the Nirvana guide I've checked the voltage across the fuse resistors and for all 4 of them I get a reading of 1.5/1.6 V.
Also I get a mains reading of +-37.6V
These levels are correct for the stock 55 but in the Nirvana kit the levels mentioned are 5 to 7 V for the fuse resistors and +-33V for the rail voltage. Whats going on and what can i do??  :?:  :evil:  :?:  :evil:
My ps output is obviosly the same as the rail voltages.
Nick.
AKSA
« Reply #1 on: 30 Jan 2003, 10:02 am »
Hi Nick,
No problem;  your AKSA is fine.
The instructions are given for an upgrade from stock;  so they assume that your AKSA has already been biased up for stock operation.
My apologies for the misunderstanding;  I will correct this on the instructions.
For now, bias up exactly as if it were stock.....
Hugh
