Best handshake between a Media Player and CD Ripper
0 Members and 1 Guest are viewing this topic. Read 2058 times.
davidrs
  • Which do you value more, happiness or truth?
« on: 17 Feb 2011, 03:26 pm »
In your opinion, which Media Player integrates best (is more seamless) with:
- EAC
- dBpoweramp
Primary (and likely only) use of the Media Player in my application will be for audio, therefore, audio integration is what is important (and not other media functionality).
David.
Vincent Kars
  • The Well Tempered Computer
Re: Best handshake between a Media Player and CD Ripper
« Reply #1 on: 20 Feb 2011, 12:13 pm »
The answer is it depends on the file format you are using.
MP3? All media players will do.
WAV? Tricky as there is no standard for tagging WAV: http://thewelltemperedcomputer.com/KB/WAV_KB.htm
FLAC? Any media player supporting FLAC
My personal preference: dbPoweramp + J River Media center
dbPoweramp: AccurateRip, fast, easy to configure, AMG for tagging
JRMC: support of many audio formats, versatile interface, multiple drivers, excellent sound quality: http://thewelltemperedcomputer.com/SW/Players/MC14/MC14_intro.htm
davidrs
« Reply #2 on: 20 Feb 2011, 02:42 pm »
Vincent,
I am currently using EAC and J River 14
File formats I prefer are WAV and FLAC
May jump to dBPoweramp based on the positive feedback from multiple users on multiple forums. It appears to be the ripper of choice.
Asked the question to make sure I was using the optimal combination, for my needs.
Thanks.
- David.
Vincent Kars
« Reply #3 on: 20 Feb 2011, 03:17 pm »
Your only worry is WAV
There is a plug-in to make JRMC tag WAV but I don’t know if it is compatible with the tags written by dbPoweramp.
You might ask here: http://yabb.jriver.com/interact/index.php#2
or simply download the trial version of dbPoweramp
davidrs
« Reply #4 on: 20 Feb 2011, 06:14 pm »
Vincent,
I've tagged via Freedb in EAC.
And I believe J River tagged automatically when I did not tag in EAC, but I wasn't 100% sure since the information was available on another file I had already created within J River.
In any case, need to test it out. Not a major hassle, but does add another step and it could, of course, be smoother.
And I'll look for the plug in wrt J. River and EAC, and definitely with dBpoweramp once I make the move.
David.
wilbert-vanbakel
  • Photoshopped Smile
    • On Facebook
« Reply #5 on: 21 Feb 2011, 05:16 pm »
I have trouble with understanding your question, David.
Both EAC and dBpoweramp convert one audio format into another: CD to digital files, for example.
I don't think that EAC enables you to edit tags after finishing the process, dBpoweramp does enable tag editing after the crime.
Would you like remote control and networking (internet radio) support on your media player? The features of your media player don't rely on the converter that you choose.
davidrs
« Reply #6 on: 21 Feb 2011, 06:51 pm »
Hi Wilbert,
Just wondering if a particular media player "interacts/interfaces" better with EAC or dBpoweramp?
The answer may be: No, it doesn't make a difference, given my limited needs/requirements.
Figured I should ask in case fellow AC members had an opinion on the question.
I'm primarily concerned about the interface and audio file playback, so the networking and remote functions are not on list (at this point).
- David.
wilbert-vanbakel
    • On Facebook
« Reply #7 on: 21 Feb 2011, 07:00 pm »
The only interfacing/interaction that comes to my mind is the tags.
Tagging helps you organize your music.
Both EAC and dBpoweramp create and store files. Your media player reads the stored files and converts that to sound.
Your media player doesn't require EAC or dBpoweramp to function, and both EAC and dBpoweramp don't care what mediaplayer you use.
You might play their produced files in you car stereo.
When converting audio source to audio files, you might be more interested in knowing how easy tagging information and album art are retrieved and how accurate that is.
