0 Members and 1 Guest are viewing this topic. Read 4034 times.
The Oppo BDP-93 is the only player that ticks all your boxes and is in your price range. There just aren't that many BDP's that are also universal players and TTBOMK the Oppos are the only ones under $1K.On the plus side, Oppo has a well deserved reputation for quality, performance and value. I have been very happy with my BDP-83SE.FWIW, the PS3 is a good player, but it is not universal.
PS3Pros: highly upgradable, netflix, online store, can hold music and video. Downside, no analog outputs, bluetooth remote, SACD support is lacking (does do DSD i guess), requires you to 'login' to use.I have the first model and it's a bit loud, so to be honest I will probably be adding the Oppo BDP-95 in the coming months, but the PS3 isn't going away.
Are there any good candidates in the $200 range? I'd like some comparison units even if I have to drop the 'universal' criterion.
My BDP-83SE has trouble playing SACDs with lots of tracks. The current beta firmware supposedly fixes the problem, but even Oppo doesn't consider it to be stable enough for "official" release. Blu-Rays and DVDs have all played perfectly.
Just picked up a Sony BDP-S470 of amazon for $109Nice picture for blu ray and upconverted DVD, super fast, and has a ton of internet connectivity stuff.Watched a bunch of previews in HD off the internet with it, worked like a charm.Also, plays SACD and sends it out as DSD or 172Khz PCM over HDMI.
