0 Members and 1 Guest are viewing this topic. Read 4111 times.
Hello everyone, two channel vinyl guy here! The closest to digital was a cd collection residing in an Escient that blew a power supply. I am told to replace it is as simple as a Mini Mac, Ipad and Itunes, connecting the Mac to a DAC and into my two channel system ... it cannot be that simple, can it?? Thanks,Bogie
This is an approach I'd like. As for external drives, containing ITunes library and music folder, how is one to keep audio files from duplicating with each successive backup. I know Time Machine syncs things, but how else can one keep from replacing files ,as Tunes would have you do, everytime you back your music folder ? I've heard software as Retrospect and ChronoSync solve this redundancy. Of course, one could always make a mental note or record files ripped from previous backup, subsequently only backup these additional files, but this seems tedious. I also wonder if one should only backup the "music" folder containing the actual audio file folders, or should you backup the ITunes "library" folder, also, thereby keeping everything organized ? I referring here to your "backup" drive, not the "working" drive from which you play.author=newzooreview link=topic=91450.msg906728#msg906728 date=1297827622]I'm getting sound as good as vinyl from my Mac + DAC setup, but all the details matter.I have a MacMini, modified by Mach2 Music (http://www.mach2music.com/)That's feeding a dB Audio Tranquility SE DAC with Essential SE USB cable. (Yeah, it's pretty easy to hear the differences between USB cables). http://www.dbaudiolabs.com/signatureDac.html The music is in AIFF format on an external Firewire 800 drive connected by a Firewire cable that removes the power connection going over the cable. (Yeah, that is an audible improvement too, and I'm not really into power cables. I've tried plenty of power cable that made no difference, and my $2000 DAC uses a $12 cable. But the right cable with the right component does matter).I would never ever consider vinyl or a standard CD player at this point.And for playback software just use http://sbooth.org/Decibel/There's a lot more to say, but this is the best approach going (after having tried others and read endless accounts and theories about computer audio).I've never had better sound from my system (in 20 years) than I do now.I do not have any financial relation to any of these guys, and they have been great to deal with.
iTunes only asked you to back up if you purchase media from the iTunes store, it will not back up any CDs you ripped via iTunes.
This is a first to me, does this mean that all the CDs and other mediafiles that are not Itunes store natives, are not backed up when I use Timemachine? Should the HDD crash, will I have to do redone everything? If this is what I understood, then perhaps I should have an extension folder with the Itunes music library in it and continuously have Timemachine backing a copy of it.
I am using a Mac Mini via optical digital out to my surround receiver. I have a hard time believing that it is worth $1,000 to modify a Mac Mini since it is just a digital output. The software used can make a difference. itunes is not ideal, you need to change the setting depending upon the output you want, each time.I have a fire wire input into my receiver as well though I haven't tried that as of yet.
I am using COG and it works very well. It will decode shn, flac, apple lossless and all sorts of things. I can use it to output hi rez audio files directly.As for hard drives I highly recommend using ones with a wall wart or other external power supply. that way it doesn't drain on your computer's power supply.Just my 2 cents.
