SST to SST2 Upgrade?
0 Members and 1 Guest are viewing this topic. Read 2355 times.
Rod_S
« on: 15 Feb 2011, 12:15 pm »
Hello all, I am curious if it's possible to upgrade the SST non C series and SST C series amps to the new SST2 series via a return to Bryston? I have a 4BSST, 4BSST C series and a 6B SST C series and with all the excitment on the forums about the sound of the new series this type of upgrade would be of interest to me.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SST to SST2 Upgrade?
« Reply #1 on: 15 Feb 2011, 12:52 pm »
Hi Rod,
No sorry - we can do the small capacitor changes for you but that is all.
james
Rod_S
« Reply #2 on: 15 Feb 2011, 01:24 pm »
Oh well, it was worth asking about, thanks James.
Levi
« Reply #3 on: 15 Feb 2011, 01:27 pm »
That's actually great.  Caps upgrade makes a big difference in sound.
alexone
« Reply #4 on: 15 Feb 2011, 02:44 pm »
can the caps be upgraded by the dealer/distributor or can it only be done by Bryston?
al.
« Reply #5 on: 15 Feb 2011, 04:32 pm »
al.
Should be done by us.
james
rmurray
« Reply #6 on: 19 Feb 2011, 01:36 am »
Can any cap improvements be done to the 4b ST  ? :cry:
« Reply #7 on: 19 Feb 2011, 02:00 am »
I do not think so but check with Mike Pickett.
ajmes
