Bryston Headphone Interface
0 Members and 1 Guest are viewing this topic. Read 179195 times.
SoundGame
Re: Bryston Headphone Interface
« Reply #400 on: 19 Nov 2011, 03:49 am »
SR 325 and GS 1000.   I am still experimenting but I would say the dynamic contrasts and transients would be what I notice most between the preamp and the BHD - the more difficult to drive the more noticeable it is of course.
James
Dave, I believe James answered this question - at least his earlier impressions, in response to a similar question I asked.  It sound like if your headphones are more demanding from a power perspective the differences between the bp26 headphone jack and the BHA will be move evident.  It also sounds like dynamics and transients are the primary difference.  Only an audition will reveal what comes through on your headphones.  Bye-the-way, Dave, what are you using?
DaveNote
  • Without music, life would be a mistake. Nietzsche
« Reply #401 on: 19 Nov 2011, 01:18 pm »
My headphones are Audeze LCD-2s (which are not power demanding) and I am driving them with a Schiit Lyr. I was using Sennheiser HD800s with a Grace Designs m902, both of which I bought without a demo and gave away because while great were just too cold and analytical for my taste once I had the LCD-2s. The person I gave them to is producing music, so for him they are perfect. The Lyr is driving me nuts because it has a hum in it with my preferred set of tubes. The bottom line for me is that I would like a solid state HP amp that sounds like the Lyr. James no doubt doubt has given the best answer he can, but perhaps unrealistically, I was hoping or something else.
Dave
MellowVelo
« Reply #402 on: 5 Dec 2011, 05:21 pm »
Hi James,
Is there actually a difference in the level of sound quality between the internal-PSU version and the external-PSU version? Or is the external-PSU version just offered as a convenience for customers who already have the MPS-2? If there is a difference, what is the difference in terms of percentage? I know that that's pretty subjective, but if the external-PSU version offered 100% maximum sound quality, what percentage would the internal-PSU version offer?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #403 on: 5 Dec 2011, 07:44 pm »
Hi James,
Hi,
Correct - just a lower cost alternative for folks with a MPS-2 already.
james
larevoj
« Reply #404 on: 6 Dec 2011, 01:00 am »
Hi James, is the BHP-1 ready for Christmas sales?? Any updated pictures of its front and rear??  :thumb:
« Reply #405 on: 6 Dec 2011, 01:59 am »
We are in the final stages so should have some pictures soon.
james
Vipers
« Reply #406 on: 6 Dec 2011, 10:57 pm »
james
Excellent news, I nearly ordered a pair of Grado PS1000's today in anticipation but thought I'd better wait till the BHA-1 is definitely in my hands.
The million dollar question James, will the BHA-1 outperform the headphone out on my SP3?
« Reply #407 on: 6 Dec 2011, 11:05 pm »
Hi
I think so but that is a good question because the headphone amp on the SP3 actually has a dedicated Class A Discrete circuit driving the phones.  I think it will come down to the difficulty of the load as the BHA-1 will be more capable in that circumstance.
james
DaveNote
« Reply #408 on: 6 Dec 2011, 11:33 pm »
Hi
james
James are you saying you don't know if the BHA-1 outperforms the headphone option on other Bryston gear? If so, that is troubling indeed. I would be terribly cheesed off to have purchased a BHA-1 only to discover it did not outperform the headphone jack on my BP. It seems that the No. 1 design goal of the BHA-1 would have been, at a minimum, to outperform the headphone capability of the SP3 or that of other Bryston gear. Haven't you compared the BHA-1 to the headphone options of other Bryston Gear?
Dave
« Last Edit: 7 Dec 2011, 01:58 am by James Tanner »
« Reply #409 on: 7 Dec 2011, 01:59 am »
Dave
Hi Dave
Nope have not compared the SP3 with the BHA -1 as it is still being played with.
Let me try to explain this differently. The BHA -1 comes into its own as the difficulty of the headphone load becomes more difficult. Much like amplifiers the speaker load has a lot to do with the amp choosen to drive it adequately. The more difficult the load the more the amp has to work therefore a 28B instead of a 3B.
Same with headphones - the more difficult the load the more the BHA-1 makes sense. If your headphones are really easy to drive then I would probably say the SP3 would work very well indeed  :thumb:
James
mamba315
« Reply #410 on: 7 Dec 2011, 04:50 am »
I have the Audeze LCD-2's, which really need a couple watts of power into 50-60 ohms, and can handle up to 15w.  Do you know what the new amp will be rated at yet?  Voltage swing?
I looked through a few pages of this thread and couldn't find an answer.  Apologies if it's been posted.
« Reply #411 on: 7 Dec 2011, 11:20 am »
Plus or minus 33 volts of swing.
james
DaveNote
« Reply #412 on: 7 Dec 2011, 12:33 pm »
james
James, as a followup to your answer to my questions above, and mamba315's specs about the LCD2 headphones, would you consider LCD2 headphones hard or difficult to drive?
Dave
« Reply #413 on: 7 Dec 2011, 12:34 pm »
James, as a followup to your answerr to my questions above, and mamba315's specs about the LCD2 headphones, would you consider LCD2 headphones hard or difficult to drive?
Dave
Hi Dave
Can you send me a link?
James
DaveNote
« Reply #414 on: 7 Dec 2011, 12:56 pm »
Hi Dave
James
James, here are the LCD2 specs:
The frequency response is flat between 10hz and 1Khz. At higher frequencies the response is adjusted for headphone listening.
Impedance: 50 Ohms, nominal
Sensitivity: 91 dB/1mW
Maximum power handling: 15W
Frequency Response: 5 Hz – 20 KHz, usable high frequency extension 50 KHz.
Distortion: Less than 1% even at full output.
Efficiency: 91 dB/1mW
Maximum output: 133dB, 15W
Active diaphragm area: 6.17 square inches.
Contact pressure: 1.5 N, adjustable, comfortable headband.
Weight: 550 g, without cable.
Maximum diaphragm excursion: 2.5mm p-p
Dave
larevoj
« Reply #415 on: 7 Dec 2011, 02:25 pm »
Hi James, since you are checking up on this can you also have a look at LCD-3?
https://audeze.com/audeze-lcd-3
Specs
- Planar Magnetic Transducers.
- Custom designed Zebra wood (zebrano) earcups.
- Specially designed lambskin leather earpads.
- Left and right transducers have matched sensitivity and frequency response within +/- 0.5dB.
- Specially designed self- closing, acoustically transparent magnetic structure with highest grade Neodymium magnets.
- Frequency Response: 5Hz - 20KHz, usable high frequency extension 50KHz.
- Distortion: less than 1% even at full output.
- Impedance: 50Ohms, nominal
- Maximum diaphragm excursion: 2.5mm p- p
- Efficiency: 93dB/1mW - Maximum output: 133dB, 15W
-Transducer active diaphragm area: 6.17 sq. in.
- Input cable: Custom cable with mini XLR connectors
- Weight: 550g, without cable.
terrycym
« Reply #416 on: 7 Dec 2011, 03:22 pm »
I don't understand James's comments about drive and stuff but from what I can see is the main difference between the SP3 headphone socket and the BHA is that the BHA has balanced outputs.
I have AKG headphones which just have a normal 1/4" plug so the BHA will be of no benefit to me? In fact, all the headphone I've seen use jack plug or am I missing the point somewhere?
Getting confused by all this talk of specifications
« Reply #417 on: 7 Dec 2011, 03:40 pm »
Dave
Hi Dave,
Spoke with Stuart Taylor and he said these phones are on the upper side of difficult to drive but no problem for the BHA-1.
james
DaveNote
« Reply #418 on: 7 Dec 2011, 04:28 pm »
Hi Dave,
james
Thanks James. Love my LCD2s, so piecing the information above together, it looks like the BHA-1 should outperform the headphone jack on my BP using them. I'm looking forward to taking my headphones down to my Bryston dealer to demo the BHA-1 when it comes, and to ask him to set it up so I can compare it with the BP HP jack.
Dave
terrycym
« Reply #419 on: 7 Dec 2011, 04:44 pm »
I heard the LCD headphones at the Whittlebury Show last September and they were the best sounding headphones at the show, excepting the Stax SR-009's of course.
