Bryston Headphone Interface
0 Members and 1 Guest are viewing this topic. Read 179207 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Headphone Interface
« Reply #360 on: 11 Oct 2011, 07:22 pm »
Preliminary literature for Bryston headphone amp:
james
DaveNote
  • Without music, life would be a mistake. Nietzsche
« Reply #361 on: 11 Oct 2011, 07:59 pm »
James, I'm confused by the paragraph on the first page of the brochure about changing a single ended 1/4" plug. Clearly there is a jack for such a plug on the BHA-1, which means I suppose you could use a 1/4" plug. So I'm wondering what this paragraph is telling readers. Under what circumstances would users need to, or want to, use the "remedy" of changing such a jack or getting an adapter for a headphone?
Dave
« Reply #362 on: 11 Oct 2011, 08:22 pm »
Dave
Hi Dave,
If the headphone cable has 4 conductors then we can modify the cable from a 1/4 inch phone plug to a Balanced XLR 4 pin or left/right stereo XLR 3 pin connector.
james
larevoj
« Reply #363 on: 12 Oct 2011, 06:58 am »
james
Hi James, is there a pdf format or a higher rez picture? I can hardly read the prints...
« Reply #364 on: 12 Oct 2011, 11:00 am »
Yes - email me at Bryston - I am off to RMAF show so I will try to get it to you soon.
james
larevoj
« Reply #365 on: 12 Oct 2011, 11:10 am »
james
Have a good trip!  :D
mkaiser
« Reply #366 on: 22 Oct 2011, 11:47 am »
Hi James,
Have you figured out a cost for the powered and non-powered yet?
Has Bryston started manufacturing the BHA.
Mark
« Reply #367 on: 22 Oct 2011, 03:10 pm »
Hi James,
Mark
Hi Mark
Yes- $1295 suggested list US for the internal power supply version as an introductory offer. Still working on the non powered supply version but should be about $1100.
James
mkaiser
« Reply #368 on: 22 Oct 2011, 03:26 pm »
Hi Mark
James
Great, thanks JT.... I can hardly wait to get it  :thumb:
Marius
« Reply #369 on: 22 Oct 2011, 03:44 pm »
Hi James,
Would the powered version be power-bypassable?
I have the Bp1.5 so dont need the powered version, but would like it to be futureproof, and as versatile as possible. Might well be I 'd use it in another setup, where the Bp1.5 is not around...
Marius
Hi Mark
James
« Reply #370 on: 22 Oct 2011, 04:05 pm »
Hi James,
Marius
I do not think so as the backboards are different but you could change the backboard and install the transformer - I will ask engineering.
james
Marius
« Reply #371 on: 22 Oct 2011, 05:43 pm »
HI James,
Ok please do. Great.
Would have hoped for a universal backboard, with the BHA having a powersource installed, and an extra connection for the external BP1.5. If plugged in, use the external Bp1.5, if not plugged in use the internal powersource.
It's no price concern, just a matter of universal flexibility.
Hope to hear from the engineers..
and of course still waiting for an answer about the tapeloop pass-through too.
Marius
james
« Reply #372 on: 22 Oct 2011, 08:04 pm »
HI James,
Marius
No tape loop pass-through.
james
Marius
« Reply #373 on: 23 Oct 2011, 08:08 am »
No, I meant your suggestion of using the seconde out's on the bp26 and modify those .
Marius
james
« Reply #374 on: 23 Oct 2011, 11:56 am »
Marius
Yes that can be done but not by the customer of course.
James
Marius
« Reply #375 on: 23 Oct 2011, 04:23 pm »
Of course , I wouldnt dare. :nono:
James
Vipers
« Reply #376 on: 27 Oct 2011, 07:55 pm »
Hi James,
I'm just about to order a BP-1.5 to go with my SP3, now I've got the ordering bug again and am wondering if it is possible to order a BHA-1 yet for the UK? and if so, how much for the non power supply version?
« Reply #377 on: 27 Oct 2011, 07:57 pm »
Hi James,
Hi Vipers,
You would have to check with PMC on the pricing - in Canada the non-transformer version is $200 less. We have run into some metal work issues so we are still about 3-4 weeks away from release.
james
Vipers
« Reply #378 on: 27 Oct 2011, 09:35 pm »
Hi Vipers,
james
Thanks James, I'll check with PMC tomorrow.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #379 on: 28 Oct 2011, 06:54 am »
Hi James,
Chances are that if you fly to Toronto, rent a car to drive to Petersborough, shake James's hand, load the boxes into the trunk and fly back to the UK you will be a lot cheaper off than when buying it through PMC...
