0 Members and 2 Guests are viewing this topic. Read 179258 times.
Hi James,I cannot be sure (because of the low resolution of the pictures) but the XLR jacks on the BHP-1 look like they are male. Can you please clarify?Thank you
Hi,I will check - meaning they should be female? I have been told there is no standard as such - on the preamps and amps the signal always moves from a male into a female.james
Hi James,Most of the balanced headphone amplifiers I know of have female output XLR jacks/receptacles. I do not know if it is a technical reason for this or is there an industrial standard. Perhaps other more experienced headphone users here can advise.Thank you
Hi larevojWe care moving away from the battery unit for now and the BHA-1 will be available with a built in linear power supply or can be used with our external MPS-2 power supply. James
I have been doing some research and soon auditioning a few head phone amps and headphones around town. It is unfortunate Bryston is not pursuing the battery option as there are many performance advantageous with battery supply and one example is from RWA Audeze's Edition - http://redwineaudio.com/components/audeze_edition.Perhaps making the battery supply as an option for folks whom doesn't want to have a built in linear power supply unit and using MPS-2 to charge up the battery supply unit?
I like that.James,is there only an input for the MPS-2 on the front.I see there's a IEC on the back,can't see if there's connection for the MPS-2 on the back.
The MPS-2 is the power supply only and has 4 power outlets on the back.
So shouldn't we be seeing one of these instead of an IEC connector on the back of the BHA-1? Steve
James - might have been covered earlier but will a BHA-1 with an internal power supply benefit from using the MPS-2 in the event one acquires a BP-26/MPS-2 set up down the road?TIARon
Looking good James,A black one for me please without the internal Power supply quick question, If you choose the version which goes with the MPS-2 will the BHA-1 come with the correct cable to connect to the MPS-2?Thanks.
JamesHave you set pricing yet for both versions ?
