BCD-1 output volume
0 Members and 1 Guest are viewing this topic. Read 1115 times.
SeanS
BCD-1 output volume
« on: 12 Feb 2011, 05:14 am »
I'm sure this has been covered somwhere. But is there any adjustment on the output volume of the BCD-1, I'd like it a little lower for my pre.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BCD-1 output volume
« Reply #1 on: 12 Feb 2011, 12:22 pm »
Codes:
240 Adjust display brightness, PLED display only.
241   Trigger input enable/disable
242   Display Shut-Off enable/disable, "0" button will toggle display ON/OFF
250   DAC Output Level  0dB
251   DAC Output Level -1dB
252   DAC Output Level -2dB
253   DAC Output Level -3dB
Remote Backlight on/off = Code 797
Remote Motion Sensor on/off = 792
If there is no output at all, please try entering 'code 2, 5, 0' on the remote.
This is the code to set the BCD1 to full output, and if for some reason the output is being attenuated in software, this will restore it to full.
