New upgrade available for push-pull amplifiers: Precision phase splitters!
0 Members and 1 Guest are viewing this topic. Read 2220 times.
Niteshade
    • Niteshade Audio
Just when you thought it couldn't get any better...it just did.
A precision phase splitter does the following:
1] Increases average and peak power output
2] Increases transient response performance (cleaner peaks)
3] Improved sub-watt performance
I developed this upgrade as a means of improving our already high performing phase splitter. This upgrade makes it possible to drive the power tubes more efficiently through a perfectly balanced splitter output.
Some Advantages:
1] Smooth as glass transient response reproduction
2] Class A performance without the heat and tube wear
3] A wider, more enveloping sound stage with highly accurate instrument placement
4] Excellent instrument/vocal differentiation during complex, demanding passages
5] Lower noise floor due to a more efficient power amplifier
poseidonsvoice
    • 2 channel/7 channel setup
Is this a circuit or an interstage transformer?
Anand.
Niteshade
    • Niteshade Audio
This is a tube phase splitter circuit. It works much like an interstage in terms of benefits.
