Speakers for iDecco
0 Members and 1 Guest are viewing this topic. Read 2771 times.
Mightyburner
Speakers for iDecco
« on: 10 Feb 2011, 02:10 am »
Maybe this isn't the right Circle but I need help/suggestions.  After a few months with the ERA DS4.5's I feel like the soundstage isn't quite what I'm looking for in my secondary system. It seems small with minimal depth.
So far I've only auditioned the Nola Boxers. The speakers sounded great to my tin ears but a little directional. When I shifted only sightly from the center spot the soundstage just collapsed and I could easily locate the speakers even with my eyes closed. The dealer is a great guy and offered to let me take them home for a few weeks so I will likely give that a try. Another contender I'm considering trying is the Ohm Acoustics 1000 speaker but I never heard them. The omnidirectional concept is interesting to me but the WAF might be an issue.
With the iDecco I will need speakers that are relatively easy to drive in my small 14X11 room. I listen mostly to jazz, blues and some R&B (the real stuff,,not that processed garbage being produced today,,,enough of my ranting). Now the hard part,,,my budget is limited to a maximum of $2,000. The less the better. Used is OK as well.
Any input would be appreciated.
Mightyburner
Re: Speakers for iDecco
« Reply #1 on: 10 Feb 2011, 01:28 pm »
Anyone?  I can't be the only one with an iDecco or Nova.
jlafrenz
« Reply #2 on: 10 Feb 2011, 01:59 pm »
Just as another option if you like the speakers you have, have you tried adjusting their positioning in the room to get the proper sound from them?
I have a Decco 2 paired with Aurum Cantus and have noticed that the width of the sound stage is quite wide, but is a little flat when it comes to depth.
Pirate
« Reply #3 on: 10 Feb 2011, 02:32 pm »
Check 6 Moons reviews.  These sound like one of the best matches and fit your budget.
http://www.6moons.com/audioreviews/gallo10/strada.html
Good Luck!
Charles Xavier
« Reply #4 on: 10 Feb 2011, 03:02 pm »
These may be to large but ZU always sold their speakers with these units
http://www.audiocircle.com/index.php?topic=86177.0
http://www.zuaudio.com/
check them out on Facebook also
« Reply #5 on: 11 Feb 2011, 05:02 pm »
I like my Ascend Acoustics CBM-170s and I'm sure their bigger, more modern speakers are even better.
