Bass damping adjustment
0 Members and 1 Guest are viewing this topic. Read 1928 times.
soarertoy
« on: 7 Feb 2011, 10:48 pm »
Hi,
Question for Brian - which recordings do you find most useful when tuning the Passive Radiator, and why?
Richard
Brian Cheney
    • http://www.vmpsaudio.com
Re: Bass damping adjustment
« Reply #1 on: 7 Feb 2011, 11:05 pm »
Just about any recording you're familiar with that has deep bass will work.
The key is to remove very little putty at a time, about as much as will fit under a fingernail.  Listen for clarity and definition of the bass, as well as extension.  If the sound becomes less clear, restore the putty you just removed.
John Casler
« Reply #2 on: 14 Feb 2011, 12:50 am »
Here are a couple:
1) Victor Wooten and Improv/Amazing Grace (Live Version) on the Bela Fleck Acoustic Live Art [Live]
 album.
Almost anything by Victor Wooten (LOOK HERE)
2) Dean Peer playing LORD'S TUNDRA off the UCROSS album
Take a listen to it HERE
« Last Edit: 22 Feb 2011, 09:02 pm by John Casler »
