Piccolo Question
0 Members and 1 Guest are viewing this topic. Read 1266 times.
Aerobat
Piccolo Question
« on: 6 Feb 2011, 01:55 pm »
I just built a Bugle, and have a Piccolo on order to use with LOMC cartridges.  My question is, can I have the Piccolo connected and set to zero DB gain when using MM cartridges?  Or should I disconnect the Piccolo completely?
Mark
poty
Re: Piccolo Question
« Reply #1 on: 6 Feb 2011, 06:33 pm »
Yes, you can leave the Piccolo connected. If you use half-kit you should make the «off» to 0dB conversion.
Aerobat
« Reply #2 on: 6 Feb 2011, 06:49 pm »
Great - I might just wire the Piccolo and Bugle together in the same enclosure.
