4BSST Gain Setting Questions
0 Members and 1 Guest are viewing this topic. Read 1221 times.
past_or
« on: 5 Feb 2011, 06:35 pm »
Hey everyone. I have a 4BSST and for the longest time my right channel was quieter than the left. I thought it was simply my hearing, or speaker placement, but I finally decided to switch the L/R speakers to the opposite outputs and it confirmed that something was up with my amp. For some reason I decided to fiddle with the gain settings. I am running XLR and had put both gain settings on 1Volt. I set my left channel to 2Volt and the right channel to 1Volt and my system came alive and sounds WONDERFUL!
Any thoughts on what should be done or why I am having this issue?
Is it worth sending back to Bryston, or should I live with it?
Thanks for you comments.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 4BSST Gain Setting Questions
« Reply #1 on: 5 Feb 2011, 07:48 pm »
Hi,
Did you try swaping the left and right XLR inputs to the amp just to make sure it is not a cable problem -  if one of the balanced cables was not wired correctly it would cause a gain mismatch?
james
