Cutting 7"-12" holes ?
0 Members and 1 Guest are viewing this topic. Read 1820 times.
RSE
« on: 5 Feb 2011, 01:10 am »
This has probably been covered...however I did not see a 'search' within a particuliar circle, and am not too familiar with this site.
I'm trying to find the best way to cut holes for the drivers?
What have you guys found to be easy and efficient (clean)?
Norman Tracy
    • Audio Crafters Guild
Re: Cutting 7"-12" holes ?
« Reply #1 on: 5 Feb 2011, 01:30 am »
jeffh
« Reply #2 on: 5 Feb 2011, 01:55 am »
If you have a router the best bet is the Jasper Jig.
http://www.jaspertools.com/
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=365-250
Great recommendation.  The Jasper circle jig works great.
Bemopti123
« Reply #3 on: 5 Feb 2011, 02:17 am »
BTW, Jasper works with only a plunge router.
Scott F.
« Reply #4 on: 5 Feb 2011, 01:10 pm »
You can drill a hole a little bigger than the size of the router bit at the edge of the radius of the circle and still use the Jasper if you don't have a plunge router.
